The current line of iPod touch comprises seven (7) different generations.
3399вопросов Показать все
What can I do if I forget my password?
Someone stole my ipod and changed the password when i found it i didn't know the password so i need help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
6 Ответов
Выбранное решение
You can do it, but it requires the iPod touch to be reset, hopefully you have synced it recently with iTunes before it was stolen?
Ok so connect your iPod to iTunes
Hold power button and Home button (circle button) at the same time, maybe around 8 to 10 seconds.
It should now reboot (screen will go off), release JUST the power button, keep home button held down.
iTunes will say it has found an iPod in recovery mode.
Now just restore your iPod with your iTunes.
It will wipe everything first, then put it back on.
Был ли этот ответ полезен?
Оценка 2
Комментарии:
Dude. thank ou so much.
из
OMG it will delete all my photos!!!
из
it better to get restored.
Оценка 1
Can’t access your iPod? To reset a lost iPod password, follow these instructions.
1. Plug your iPod into your computer.
2. Make sure you have the latest version of iTunes.
3. If necessary, back up all your music. Though you may think that this is impossible with a locked iPod, the screen lock only protects the iPod interface itself; it doesn’t protect/encrypt any of the data inside, meaning you can still access it from your computer.
4. Restore your iPod. This will clear its contents and restore all factory settings.
5. Re-sync your iPod and apply a new password.
More from: http://www.wikihow.com/Reset-a-Lost-iPod...
Оценка 0
it doesn't work!!
Оценка 0
thank you man you are the best
Оценка 0
Well, i just have the same experience with you. forgetting the passcode of a iDevice, but my iDevice is an iPad. But i think maybe the way to solve the problem is similiar, so i recommend you to refer to https://www.isunshare.com/iphone-ipad/re....
Hope to be helpful.
Оценка 0
Добавьте свой ответ
jaylin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 5,547
