GoPro Hero 4 Black Complete Freeze
The camera will not connect to my computer. And I cannot access it via wifi, as I cannot turn the wifi on.
Because every time I press the shutter button, the camera freezes completely and must be shut off before it will do anything else. But the problem simply repeats itself no matter what I try.
I cannot update the software, nor check the contents of the camera.
Is there anything I can do?
Это хороший вопрос?
7 Комментариев
well i have an issue with my hero black. it keeps freezing plus i can pink film on the photos. also the videos are damaged now and it's useless. used the camera few times since the date of purchase but the warranty doesn't apply any more. i contacted gopro support and they said it's a manufacturer fault and you need to buy a new one i which i will never do it again.
have anyone faced similar issues like that and if yes what did you do.
Thanks,
из Hassan
Very good
Thanks 03/07/2017 Jafar
из jafar
Replacement board bought from ifixit, still having old 2.0 firmware. Board will freeze after a short while. Unable to update firmware, once the SD card is inserted, the LCD only showing 'Busy'
Pretty sure it's not the camera sensor as everything was working fine, except that my previous USB port was out, hence this replacement.
video here: https://youtu.be/VTQs8eKfBew
Does anyone have any solution?
из CF Fong
did you ever find a solution
из Jorge Vallejo
Dear Jorge Vallejo
I had logged my problem to ifixit.com, they are suspected that the mainboard they send it to me previously was problem. They will ship out the new mainboard to me soon. Will update back once i received it.
Regarding my previous problem, its strange because i can update my firmware right after turning ON with a firmware file loaded in the SDcard. But after that it will freeze randomly whenever i try to record or capture the picture. Even if i ON it with no SDcard in it, it will freeze shortly. I wonder why...
из Nur M Fadhli Mahbob
Показать 2 больше комментариев
