A point-and-shoot camera by Kodak released in 2006.
7вопросов Показать все
formatting SD card repeatedly
Continues to format SD cards repeatedly, saying it needs to be formated after each formatting.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Lillie Irene seelye, try a different SD card.C-, M-, V-, and Z-series cameras accept SD and SDHC Cards. SD/SDHC Card Sizes KODAK recommends use of a KODAK SD Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB). Stick with the 2GB cards If that still does not work, you may have to disassemble your camera and check the SD card reader.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
How do I check the SD card reader (what to look for)? I am running into the format looping issue after a drop (I believe), even when using SD cards that have been used with the camera previously (256MB). Also, write protection sometimes gets engaged when putting in the SD card, which might be related
из
Ingus Valters Briska check the physical aspect of the reader. Check the lever that “feels” for the wite protect. It it bend etc? After that make sure all the solder connections are in order. Sometimes a quick reflow works.
из
Use a 2GB card or smaller. I have bought 2GB cards that were really mismarked 4GB cards. They did not work.
Оценка 0
Добавьте свой ответ
Lillie Irene seelye будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 64
За всё время: 2,185
