Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75вопросов Показать все
Do the s5 and s5 active use the same screen/digitizer?
if so, is there a difference in difficulty?
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
u2r5150, compare the S5 guide on here with the S5 Active one on here. Only you can make the determination with what degree of difficulty you are comfortable with. The display assemblies are different.
Samsung Galaxy S5 Display Assembly Изображение
Инструкция
Samsung Galaxy S5 Display Assembly Replacement
Сложность:
Модерировать
30 minutes - 1 hour
Samsung Galaxy S5 Active Display Изображение
Инструкция
Samsung Galaxy S5 Active Display Replacement
Сложность:
Модерировать
20 minutes
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
whether or not the amoled is the same I don't really have a good answer. I've only tried once to put a regular s5 amoled on an s5 active for any period of time and it was glitchy so I just ordered the right part. I use regular s5 displays to test s5 active boards all the time though. Of course the glass is different
из
@bobby what do you mean by gliychy? But does the s5 amoled works on s5 active?? And does it fit?? Thanks! :)
из
Can you use a Digitizer from a sprint s5 sport which is sm-860p and replace the cracked screen of a at&t s5 active sm-g870a ?
Оценка 0
1 Комментарий:
You ever find out if you could do that ? I need to take screens apart but I am having issues becuase of the gold connecter being so different from a kyrocera phone. Lol I'm trying to be cheap this sucks
из
Добавьте свой ответ
u2r5150 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,306
