Liquid damaged, need SSD removal or data recovery
Hi,
We need to recover important and precious pictures off our MacBook 12" Retina 2015. Either by removing the SSD if possible and placing it in some sort of caddy if available or some form of data recovery to recover our pictures. We have pictures of our young children and our 7 week USA holiday so we are devastated :(
Any help would be greatly appreciated!
Many Thanks
Update (09/15/2015)
Hi, I have got back to the UK now and have stripped the computer down and cleaned it bit by bit. The logic board is showing a small white LED when the charger is connected/batteries. However, nothing else is happening, can't power up etc etc.
Can anybody suggest anything?
Where could we purchase an upper case for the laptop? If someone thinks that it will work. I will try it. Is there anyway of being able to remove the Toshiba SSD off the Logic board and place it into some sort of external caddy/drive to remove the pictures, we are very desperate to retrieve these pictures. Any help would be greatly appreciated!
Update (09/23/2015)
Hi there, Thank you to everyone for all their help.
We managed to swap the logic board into a new Macbook and retrieve our pictures and everything on it. After a further clean up we managed to get the original Macbook working.
Once again, Many thanks to everyone who helped.
Это хороший вопрос?
2 Комментариев
Did you make any backups or send your pictures to anyone? if you did you might be able to recover some of your pictures.
из Dan
At this point I think you'll need to buy a second MacBook and swap out the logic board to recover the contents of your SSD. The problem you face right now is the system is so new I don't know of any parts availability.
из Dan
