The water coffee just dribbles out
I cleaned my brewer with white vinegar and used the paperclip trick. The water comes out nicely when there is no K-Cup or if I use the cup that you put your own coffee in. When I use a K-Cup, the water coffee just dribbles out. It's got to be related to that tube and how the coffee exits the basket when the K-Cup is in there, but I just can't figure out what the problem is...
Это хороший вопрос?
8 Комментариев
Dump the Kuerig and buy a different coffee maker.. Ive had 3 Kuerigs and they all quit. Waste of money...Im done with Kuerig.
из Harry Stout
IMO most owners just use their Keurig everyday until it quits working properly. Keurigs need maintenance more than other coffee makers. You need to clean the head with a paper clip occasionally, run a brew without a k-cup (will help keep coffee grounds out of your cup) and clean Keurig with vinegar every 2 months. My first Keurig was a B70 that I purchased at Goodwill for $5.99. I now have a Keurig K575 with Carafe, I can use any k-cup and have all menu options using a special clip purchased at Amazon.
I purchase Keurigs at Goodwill and get them working properly and have given 6 Keurigs to family members and 2 to friends. I love Keurigs!!!!
из Dan Taylor
What special clip
из donna wilborne
@donna wilborne - Full Menu Clip, Metal Freedom Clip by Geesta on Amazon $10.99. You receive 2 metal clips 2 orange tabs plus extra orange stickers, You just snap (1) clip on and install (1) orange tab. The cost will be recouped quickly because you can use any k cup or use a refillable. You will no longer get the "Oops Message".
из Dan Taylor
@Dan Taylor - I was not aware of those clips. I use the My K-Cup, which also unlocks the full menu, but, I use my own coffee. I'll look into the clip, though. Thanks!
из Brian Blake
Показать 3 больше комментариев
