Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1622вопросов Показать все
Вопрос закрыт
AirPort/Bluetooth assembly, minding the fragile antenna Cables
when I was changing the cable one of the Airport/Bluetooth cable broken .
Can Any one tell me how much it cost and where can i get that from, the broken cable is from wireless side
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Ouch! Not good.
If you are speaking about the antenna cables they are part of the display lid assembly. You would need to take the lid off completely following this IFIXIT guide: MacBook Pro 13" Unibody Mid 2012 Display Replacement and replace the complete display assembly as Apple doesn't sell the discrete parts within the lid. The other option is locating a junker to steal the parts from. But you may find just replacing the lid assembly will be easier and less risky.
Frankly, if you lost one of the WiFi antennas then why don't you locate a USB dongle and work around the problem. While its not ideal it will get you there.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 94
