Why do I have to first unplug my computer to start
Before I can start my desktop must first unplug it till the motherboard light goes out , then I can plug it in and start the computer . Ive had this problem for several months on a computer thats used every day. Is my only recourse to replace the motherboard
Это хороший вопрос?
4 Комментариев
Does the computer post and then not come on or just do nothing at all no beep. It could be a couple of things . Power supply could be going bad or static discharge in the mother board
из Jimfixer
It does not beep or anything when you turn on only does nothing. When you unplug it it makes a sound through the speakers like a pop then the light on the motherboard goes out and then it will start after you plug it in. It hen works fine
из Jein won
I'm having the same issue. Could it be something with this new Windows 10? It seems that this issue started not long after I installed the new OS.
из Rob
My windows 10 was installed after it started this so it has nothing to do with windows 10 it may be for you but not for me
из Jein won
