This Samsung Syncmaster 940NW monitor works fine except for the fact that it turns black after a few minutes. A few minutes means: 5, 10, 15, 20 or whatever minutes it likes to stay on. What could be the cause for this blackout?
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
1 Комментарий
did you do a backlight test? is there any video?
Any problem associated with a time to react must have a heat component. Any component can do that, so starting with the easiest to test is the way to go.
Black screen - backlight test. then capacitors, then voltage checks, then it gets difficult and becomes a board swap process.
3 Комментариев:
THX Oldturkey. I will check this out as soon as I have time.
I am using this monitor (Samsung Sync Master 940NW) for more than one year. Since a month the screen stays black after switching on my pc. I am using two monitors, so I am able to work, but some frames start at the SyncMaster and so I am not able to continue. The issue takes 5-10 minutes. The manual can be found here:
monitör 5-10 dakika beklemeden sonra çalışıyor olsaydı kondansatörler nedeniyle bu problemi yaşamış olurdun. Ama senin problemin açıldıktan 5-10 dakika sonra kapanması. bu ekran kartında veya panele bağlı olan kartta problem olduğunu gösterir. bu da ölçüm yapılmadan bilinemez.
Translation Turkish - English
If the monitor was working after 5-10 minutes of waiting, you would have had this problem due to the capacitors. But your problem is that it turns off 5-10 minutes after it is turned on. this indicates a problem with the video card or the card connected to the panel. this cannot be known without measurement.
That is exact what is happening. You suggest the problem is the capacitor(s). But which one. I assume within the power supply. Do you have more information. I would be pleased
1 Комментарий
из bill Поделиться
