12.1 Megapixel CMOS type sensor camera. has 14x optical zoom. Supports SD, SDHC and SDXC cards, as well as MultiMedia card and MultiMedia Card Plus and MMCplus cards. Uses a nonstandard battery.
10вопросов Показать все
I broke my LCD screen?
I dropped my camera. The LCD is cracked and i can't see anything, however it turns on and off. Do i need to replace the LCD with backlight? can i replace the LCD without backlight? thankx
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I think you'll find the screen and backlight come as a unit. If you hang out on eBay, before long you should be able to get another camera of the same model and with a different fault such as a lens error quite cheaply. Swapping the LCDs should then be relatively simple.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
ohmygoodness23 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 311
