iPod Classic 160 Gig Back light doesn't work
I accidentally washed my iPod classic but it works fine except the back light is out
Это хороший вопрос?
Это хороший вопрос?
Thomas Overstreet, not quite sure how you washed it, but at minimum you will need need replace the HDD and the battery anyway since it will corrode and fail. While you have your iPod dismantled, clean everything with a high grade isopropyl alcohol and a soft brush. Do not forget any connectors etc. After that you will need to replace the display and hope that this will fix your backlight. If it does not, then the backlight circuitry on your logic board has shorted out.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 254
1 Комментарий
I made a mistake, I have only an 80 Gig and want to upgrade it while i have it open to a 160 Gig
из Thomas Overstreet
