2009 Honda Shadow Spirit 750 gas leaking from carb
at times gas leaks from some where on the carburetor trails down the choke knob can't see where it's coming from trying to avoid taking off tank to get a better look
Это хороший вопрос?
Это хороший вопрос?
See if this video on how to diagnose and repair a leaking motorcycle carburetor helps, here: https://www.youtube.com/watch?v=gbfMEYG8...
Also take a look at the excellent answer from Old Turkey here: Nipple on the bottom of the carburetor?
Был ли этот ответ полезен?
David G, you may have some leaking vacuum lines, which siphons some of the fuel out. Hard to determine unless you really take a good look at it. Since you did not tell us how your Honda runs when the fuel teaks, it is also possible that your float / needle valve is getting stuck and your carburetor floods.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 6,138
