Why are my hinges loose on the headphones
My beats solo hd they fold when i move around they dont stay firm
Это хороший вопрос?
Это хороший вопрос?
blade6462, loose hinge pins can cause this. Remove the cover plate on each side and you will see how the pins are inserted. It is possible that either they are worn or the holes where the pins go through is starting to wear out. Sometimes you can fix this by replacing the pins with slightly larger ones.
Был ли этот ответ полезен?
Beats studio loses from left side hing is ok but hing connect to band from there its loses what i do now :(
how do i fix this problem for my beats because i tried everything and nothing works.One side is opened!
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 40
За всё время: 14,304
