iPhone 6 LCD all black. Digitizer and all other functions working.
This phone has hit the ground pretty hard and has been bent quite a bit. The LCD and everything else were working fine for a couple months after the damage, then the other day the LCD went out, while everything else still functions properly (digitizer, speakers, calls can be taken, power and volume buttons). Images are included below.
I removed the screen and tried a new replacement with no luck. Same thing.
I checked the LCD FPC connector, and it looks fine. The only thing I haven't done is remove the logic board to check for dirt or anything else under that may be causing a short.
Any other suggestions are welcome, especially if you've come across this issue before.
Thank you.
Это хороший вопрос?
3 Комментариев
When you replaced the screen did you unplug the battery before removing the display assembly?
из Chasity Miller
Yes. That is my first step, every time.
из Rick Ross
Do you solve this problem ?because we have a same problem, please help me for this problem thank you.
из saidedizonmohammad
