iPad 2nd generation not charging
How can I change or replace the battery?
Это хороший вопрос?
Это хороший вопрос?
Are you sure its a battery issue? Does the device show its charging when you plug in a charger?
Был ли этот ответ полезен?
The battery is behind the LCD. You would have to remove the glass screen, and then the LCD and you will see the battery. After removing both the glass and LCD its easy to access the battery. What will take time is the adhesive around the glass.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 428
This question was migrated from http://meta.ifixit.com/Answers.
из iRobot
