My 73' mitsubishi WD-73734 has a green blinking light that won't stop
I have a Mitsubishi 73" WD-73734. I replaced the lamp and now the green light won't stop blinking I even pushed the factory reset and it is still blinking.
Это хороший вопрос?
Это хороший вопрос?
sassiekat2004, I'd start with the error code check:
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Let us know what if any blink code you get
Был ли этот ответ полезен?
My green light is blinking 1 time and then slight hesitation and then blinks twice what's my code
@Chuck Hensley that is for a WD-73734? which light is blinking?
Green light blinks about five times and then the TV turns Off by itself.
I have a new projector blud but a black screen
@c1fc22wnavusui1 What make and model? What were the issues? What do you mean by « new projector »?
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 24
За всё время: 4,831
3 Комментариев
Which green light? The Lamp LED?
из oldturkey03
Blinking green light constantly Flashes tried everything suggested
из Diane Poggioli Serpati
My green light blinks 1 time and slight hesitation and then blinks 2 times what's my code number
из Chuck Hensley
