MacBook Pro Sensor Palm error (Tsop--24)
Hi everyone,
Here my issue. I replaced my broken trackpad few months ago. The problem is, as soon as i boot, the fan runs at 6000 rpm all the time and the computer runs very low.
When i switch the new Trackpad Flex cable with the old one, the trackpad stop working but the fan and computer runs normally. So, it's seems to be an Trackpad Flex Cable issue, related to temperature/heat sensor.
AHT
Running the AHT test, i get the following error as you can on the image below (yes, i'm french):
4sns/1/c0000008: tsop -- 124
Temperature Gauge Pro
We see that the Palm rest sensor don't seems to be malfunctioning, but that fans runs at maximum capacity.
Below, the same screenshot with the old cable (i use an optical mouse to replace the trackpad)
In addition, here a photo of my motherboard and the new cable (i cleaned up the dust right after ; ) )
Thank you in advance for your expertise.
UPDATE
Close-up view of the trackpad
Output of lm-sensors
Это хороший вопрос?
2 Комментариев
I tried numerous solutions already: reset SMC or PRAM didn't solve the issue.
из dibalias
In addition, i tested safe mode. The problem persists.
из dibalias
