Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
Вопросов 20 Показать все
Why can't I install OS 10.3 in this clamshell?
This machine (192 MB RAM) is currently running OS 9.2. Works beautifully. I have updated it with Firmware 4.1.7 update. Verified it as its Boot ROM is now 4.1.7f4. I booted off a cd 10.3 installer but after a few minutes of hard drive activity, I get a kernel panic. Tried it several times, I get the same result. Sometimes, what I get is a message that tells me I need to reboot the computer, blah blah blah, etc. I know this cd works. And 192 MB RAM maybe small, but it should have worked. What gives?
Это хороший вопрос?
Оценка -1
1 Комментарий
Добавить комментарий
Ответов (5)
Выбранное решение
Are you sure you are using a retail disk (black) and not a machine specific (gray)?
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
+ very good guess
из
I could try resetting the PRAM. When you turn the computer on hold "Command[Apple]+Option+P+R" all at once, and keep holding it until it makes the boot noise twice. THen try and run the installation again.
Оценка 0
Thanks, Chris. But resetting the PRAM did not change anything. Sigh
Оценка 0
Yes, I'm sure the cd disk works, because I used it to install 10.3 in another clamshell weeks ago. Sadly that clamshell got inundated by a flood. It was a total loss, the water corroded many components inside. Mayer, thanks for the link. Although the Apple article mentions Powermac G3s as the affected models, I suspect a few clamshells were also involved. Thanks to all who responded.
Оценка 0
1 Комментарий:
Try replacing the ram with the ram from the other G3.
из
Yes, I've already changed RAM, even tried the 512 MB stick from another clamshell. Still no dice.
Оценка 0
Добавьте свой ответ
Bernie будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 904
