20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
98вопросов Показать все
Black stripe down the center of Apple 30" Cinema Display
I have a black stripe down the center of my Apple 30" Cinema Display. Can this be fixed?
https://dl.dropboxusercontent.com/u/8995...
Это хороший вопрос?
Оценка 2
1 Комментарий
I got the same exact problem. I really hope there is a fix other than swapping the LCD panel.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Mike Wolf, that looks like a TAB error. Sometimes applying some pressure to the binding on top of the LCD panel can resolve it. Most of the time a new panel is needed.
Был ли этот ответ полезен?
Оценка 4
4 Комментариев:
What is a TAB error specifically?
из
LCD panels use TABs to connect to the driver boards. TABs are (tape automated bonding. they sort of look like ribbon cables going form the driver board into the LCD panels.
из
@oldturkey03 Sorry to resurrect and old thread but can TABs be replaced?
из
Was this ever resolved ?
из
Добавьте свой ответ
Mike Wolf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,767
