Repair and troubleshooting help for the Memo Pad ME172V, a 2013 tablet manufactured by Asus.
16вопросов Показать все
What does it mean "Unfortunately, Launcher has stopped working?"
whenever I try to go to a website, I get the message, "Unfortunately launcher has stopped working." Any fix?
Это хороший вопрос?
Оценка 43
24 Комментариев
Sometimes my phone will say my launcher has stopped working a d I what it to go away how do I go and do that ?
из
I just had this happen , i had the same problem. You basically have a virus so go to your apps and delete the most recent one you downloaded. It worked for me.
из
You have to do a hard reset because after a while your phone will completely shut down where you cannot turn it off you have to do a hard reset which is pressing the power button and the volume up key and select factory reset and your phone should be working correctly it's going to crash your whole phone
из
What if u need the apps
из
My launcher has stopped
из
Показать 19 больше комментариев
Добавить комментарий
16 Ответов
Наиболее полезный ответ
I'm guessing you are talking about launchers on android phones. If so, the launcher usually is considered to be the home screens and app drawer.
​To resolve the error, goto settings -> Apps -> All Apps -> Scroll down to Launcher -> click Launcher -> Click clear cache -> Restart phone.
​Alternatively, you can download another launcher from Google Play. Just search Launchers in Google Play.
Был ли этот ответ полезен?
Оценка 11
2 Комментариев:
I get nothing on my screen except Unfortunately , launcher4 has stopped. OK
из
All app not display in is really
из
The Launcher is software. Today ALL software has bugs. The biggest single Android issue is the lack of memory management that would permit several apps to run simultaneously without mutual interference,the second is a total lack of clean exit/shutdown requirements for Playstore apps. Many apps, when close by a more recently opened app, will cache data from their last run. This data can easiy become corrupted.
A way to minimize the problems is to accept that Android is not multitasking. Use Developer options to immediately closed Apps moved to the "background". Clear all cache data periodically from Settings/Storage. Restart your device at least once each day, more frequently if you launch apps many times during the day.
Being the only app that runs all then time, the Launcher can be effected by other software overwriting its data, or by a shortage of memory caused by apps not releasing the memory they use.
Before trying extreme measures, uninstall any updates to the Asus Launcher app from Settings/Applications, and do a fresh update of the factory version from the Google Playstore.
Оценка 6
I cannot go into my phone I can only receive calls
When I press google it comes up
System launcher keeps stopping
When I press to send a report it does not go
Оценка 6
1 Комментарий:
Induslantur is not working
из
go to factroy reset and click on that that will work, when you you do that you will have to put all your contacks back in or go to mobile net works click on that then click off your roaming mode that roaming mode will mess up your phone where you cant use it plus you dont need the roaming moad turned on you will see data enabled there should be a green 1 on it leave that a lone
Оценка 4
Yes, my launcher has been stopped
Оценка 4
My amigo launcher has stop
When I press send report is not going
Оценка 4
The launcher has been expired
Оценка 1
How to unfortunately google stopped halping
Оценка 1
I just had it on my tv it's a virus and you need to get this virus out of ur tv
Оценка 0
1 Комментарий:
I cannot do anything unless receiving calls only
из
I have the same prob after I did factory reset. Then, I tried hard reset but prob not solved & the “unfortunately, com.asus launcher has stopped working" message keep pop up even tho I clicked ok. I tried clear cache apps, not solved.
But, finally I found a solution (you need a wifi to connect to your phone. I use wifi hotspot from my other phone). I reset factory setting first. When started, the message still pop up but just click ok. Just complete all the setup. Then the message will pop up again non stop. Just scroll down the setting. If you enter setting, it will stop pop up for a while. Then, go to system > ZenUI APP updates. It will said no result but when you click back button at the top left, it automatically send you to playstore. Just type launcher for android, and install. Boom, problem fixed.. hope it helps
Оценка 0
I have the problem of BBK launcher
Оценка 0
Mobile nai chla rha launcher ki wja se
Оценка 0
Amego loncher hasbeen stoped. Plese. Fix it
Оценка 0
Any time the unfortunately , the applauncher has been stop in your handset display in screen , Why?
Оценка 0
My moto loncher is not working properly and I can't see my apps
Оценка 0
The launcher is not good send the new launcher old launcher no good send new launcher
Оценка 0
1 Комментарий:
Old launcher is not good send new launcher
из
Добавьте свой ответ
Eli Shaheen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 23
За последние 30 дней: 123
За всё время: 73,082
