No sound! Do I need to replace my Left I/O board?
About a year or so ago I dropped my MacbookPro2,2. There is a huge dent in the bottom of the case, as if it fell on a rock or sharp point, which caused the LCD panel to be severely shattered, and my sound to die. I've been using it as a desktop with external LCD & USB sound card, but am thinking of giving it a bit of a repair so I can use it as a media center, so sound is very important.
The sound doesn't work at all; no speakers, no headphone, no digital-out optical, etc. The dent is close to the left hand side of the machine, so I'm hoping only the Left I/O board was damaged in the process. Two questions:
1. Are these symptoms common to Left I/O board failure?
2. And are all audio related circuits on the Left I/O board alone and not on the logic board?
Thanks guys
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Replacing the left I/O Board should resolve your problems.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
+ agreed
из
Добавьте свой ответ
Adrian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,545
