Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2521вопросов Показать все
Вопрос закрыт
Display assembly replacement unsuccessful, please help
i did it but unsuccesfully.
how did i go wrone there is like 5 screws
i did the complete thing step by step but screen is just black no signs of turning on. any help or advice would be great thanx
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Make sure you put the screws back exactly where they came from ESPECIALLY if they are of different sizes, i remember back in the day i screwed up the motherboard by putting a slightly longer screw in where a short one was suppose to go and it peirced the board enough to where the display showed up white with a bunch of colors and lines, good thing the board was icloud locked anyway.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
The fun part of repair! Doing everything right, then the %#*@ thing doesn't work. It happens.
Start by holding power and home at the same time for at least 30 seconds, or until the Apple logo shows up. If the Apple logo shows up, you're good. If not, connect it to your computer and see if the computer detects it. If it doesn't, do you at least see the battery charging icon? If not, time to take the screen off.
Take a look at the battery cable. Make sure there is no damage. Did you disconnect the battery connector to do the repair? Make sure its hooked back up if you did. If you still don't find anything, take the shield off the connectors and make sure you didn't miss a connector. Take each one off, reseat it, them put the shield back on followed by the screen. Hold power and volume for another 30 seconds or until it boots.
Did it work?
Оценка 1
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 101
