Dark spots on left side of LCD from top to bottom?
Dark spots on left side of LCD from top to bottom evenly spaced? They are not lines, its not a broken lcd, and its not a faulty lcd, a new one has the same spots. My only guess is maybe a backlight fuse? but the other 99% of the lcd is fine. It looks like only part of the back light is not lighting up. They are spaced about 1cm apart and go no deeper than 1cm into the lcd from the frame. And all the dark spots are identicle. Thanks! second time ive seen this, and anyone that can repair it?
Это хороший вопрос?
I have exactly the same problem. After opening iPad Air and removing display now there are dark spots. Looks like every odd LED is not working on left side. Is it a display issue? I have doubts about it.
из hlavsa
I have tried 3 different lcds its not the lcd itself. All 3 had the same issue. Like that area isnt getting power.
из TurboHommy
I have the exact same problem with an iPad Air serial DMPM, but it only occurred when I changed the digitiser. Prior to that it was slightly darker but not the "rippled" effect. After reading a lot of forums , it seems this is a common problem but mostly when they are new. Has anyone worked out how to fix it?
из Natasha Rogers
I have exactly the same problem. After switching on my iPad 4 there are dark spots which are evenly gaped. Looks like every odd LED is not working on left side. Don't know whether this is a hardware issue or iOS issue. Is there anyway to correct myself?
из Napoleon
This sometimes happens when you have pressure on the display underneath or placement of the LCD, I would try and take the LCD out and put it back in. Or look to see if you have something under the display causing the pressure that makes the backlight look funny.
из alexkasper16
Показать 4 больше комментариев
