Why is my charger for ipad 2 gets hot?
when charging ipad 2 charging adapter gets hot.
Это хороший вопрос?
Это хороший вопрос?
Chargers getting hot is normal because about 220 to 240 AC volts are converted in the charger to 5 DC volts. Chargers contain components like transformers, resistors and capacitors (among others) which gives off heat under normal load.
Charger getting hot should not be a problem unless it happens even when the device (iPad in this case) is not connected.
Был ли этот ответ полезен?
Connected to what? Mine is getting hot too. Is it a problem?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 11,328
