The V2000 is a Compaq Presario notebook computer developed by HP under the Compaq name. The V2000 is the sibling of the HP DV1000, so the two share many features and specifications, though the DV1000 cost about USD $100 more when both computers were sold in the early 2000s.
Why is my laptop not booting
My laptop turns on I can hear the fan going it beeps twice stays on for a couple seconds but it shuts right back down. Tried f1 and f10 neither worked.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Firstly 2 beeps indicates a system board problem, nothing specific is mentioned.
Have you tried turning it on with the power adapter connected and switched ON?
If so and it works you may have a battery problem.
If it doesn't, try the following:
Disconnect the AC power adapter, then remove the battery pack (Section 5-5 in the attached link) and finally reseat (i.e remove and reinstall) the memory module(s), (Section 5-10 in the attached link).
http://www.hp.com/ctg/Manual/c00444244.p...
Reinstall the battery pack, connect the AC power adapter and see if it comes on.
If not, unfortunately you have a problem with the motherboard. here is a link on how to remove the motherboard.
Compaq Presario v2000 mother board Replacement
You can go online and find replacement motherboards (check your motherboard version) but given that the PC was released 10 years ago it may not be worthwhile fixing and you may be better off buying a new replacement PC.
To retrieve your data just Google "how to get data off the hard drive in a dead PC"
Был ли этот ответ полезен?
Счет 3
Perfect answer ... Bravo
Счет 0
Добавьте свой ответ
pena буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 29
За всё время: 1,846
