The Lenovo Tab 2 A8, model A8-50, is an Android-based tablet released in April 2014. You may see model A5500-F in fine print on the back (distinct from earlier A5500 model)
9вопросов Показать все
My tablet won't charge at allor turn on.
hi, i just bought a new Lenovo Tab A8 from office depot, i got it for 15% less cuz they didn't have the charger. they said i could use my micro USB as same as my android phone. but now it won't charge at all, it shows battery drained sign, but never starts charging at all. i tried it with different micro usb chargers but no go.
any idea on how i can fix it without spending money please
Это хороший вопрос?
Оценка 3
Добавить комментарий
4 Ответов
Выбранное решение
Hi,
Ensure that your charger is 5V 2A (2000mA) output. Phone chargers may not supply enough current.
If using correct output value charger and battery drained sign still there, Press the Reset button behind the micro SD card slot cover, Hopefully it will then start to charge.
Allow tab to fully charge before turning on, then long-press the power key for over 10 seconds to restart
Был ли этот ответ полезен?
Оценка 3
Also check out these guides!
How to Hard Reset the Lenovo A8
Lenovo Tab 2 A8 Battery Replacement
Lenovo Tab 2 A8 Battery Изображение
Инструкция
Сложность:
Легко
10 minutes
Lenovo Tab 2 A8 Изображение
Инструкция
Сложность:
Очень просто
20 seconds
Оценка 0
my tablet cant turn on and have lost all the data
Оценка 0
hey. . i have a problem with my levono tablet . . the tablet works fines but the charging system isn't working at all . i tired using other cable chargers but still it wont charge and my tablet hasn't been in use for some days now and hoped you could help me fix it please . . . .
Оценка 0
1 Комментарий:
Hi,
Check the charge port with a strong light and a magnifying glass to ensure that all the pins are there, that they are straight and parallel with each other and that the port enclosure is free from dust and lint.
If there is lint trapped in the port, use a vacuum cleaner to try and suck it out. Do not use a metal probe. If necessary, use a wooden toothpick to 'gently' try to remove it.
If it looks OK, try the following:
Take the tablet end of the charge cable and plug it into the tablet. DO NOT connect the other end of the cable to anything.
Then holding the tablet firmly, grab hold of the plug which is inserted into the charge port and try to gently, stress gently move it from side to side or up and down to check if you can feel any movement at all in the USB connector.
If you can detect movement, then the USB connector may have become disconnected from the systemboard.
Here is a link to the ifixit USB replacement guide which may be of some help.
из
Добавьте свой ответ
Quincy Murphen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 15,301
