The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211вопросов Показать все
LCD Screen won't turn on
My phone was working perfectly fine but then it run out of battery and now the screen won't work, i can hear it receive messages and when i touch the screen it still vibrates as if it's working. When i put it on charge the lcd screen works and says charging... so i know the screen isn't working. PLease help.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Try a hard rest to see if that fix's the screen issue if not, try opening the phone and disconnecting the LCD/digitizer flex cable and reconnect to see if that solve the problem.
Был ли этот ответ полезен?
Оценка 0
Hello Natasha Campbell,
It seems to be phone gets stuck or core module gets not respond. as as first step just remove and reinstall the battery. turn on the phone and see whether it's working in order.
Оценка 0
Добавьте свой ответ
Natasha Campbell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 184
