Western Digital My Passport Drive. USB 3.0 Portable External Hard Drive.
73вопросов Показать все
Why is my password not working only flashing the light
my password not working only flashing the light why
my id is SAADBAIG267@GMAIL.COM
FB NAME :SAADBAIG
Это хороший вопрос?
Оценка 16
9 Комментариев:
my password not working only flashing the light why. and my windows is hang
из
Same problem here!!!
Windows 7 stop working.
In my case it look like it's the UBS adapter is not ok...
I move the cable and the light comeback, and some time the "Disk Management tool" can see my HDD, but can't initialize it.
из
I want PassPort to answer the question. That's why I'm here.
из
My passport WD was blinking and beeping. Now it's only blinking. Hasn't happened before. Truth is I barely ever use my computer anymore. After almost 30 years I'm almost totally out of Microsoft but I have lots of files & pictures there I'd prefer not losing.
из
i have similar issue here, the light to my passport is on but cant read the device? is it a cable issue?
из
Показать 4 больше комментариев
Добавить комментарий
1 ответ
You need WD Smartware. When Passport asks for password put in the wrong password 5 times it will then ask if you want it formatted say yes. Then it will work fine. You will lose all info on the disk but have functioning disk.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
what if i dont want to loose the info on the disk is there a recovery option?
из
Добавьте свой ответ
saad baig будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 10,156
