The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Car will not start, but cranks , no spark
Model: 1991 Camry DX 4 cylinder All Trac
Driving and car just cut off, towed home. No spark to plugs Voltage to distributor,and ignitor, Coil tested off ohms, replaced coil. Replaced EFI relay, and main engine relay , & ignitor , & distributor ,no start Car sat for a few days and started right up drove 2 miles coming home shut down again cranks but no start , Sat for a few days started up ran shortly and cut off . Checked all fuses
Это хороший вопрос?
Счет 6
13 Комментариев
I have a 1995 toyota camry
Just wont start NO LIGHTS NO SOUND NO CLICKING.. just nothing just dead flat
I check the battery is good.. Just wont shows any lights nor sound DEAD
из
I have a camry 2.0l , so no spark no fuel coming out of the injectors but all fuses are okay
из
Need the complete engine 5S
из
93 Toyota Corolla Kranks But doesn’t kick over I have put some degreaser on the engine and now I can’t get it to start
из
Please need help, my toyota emina 1991 model is crancking but no start.deshboard lights all ok,ignition coil power goin in but not coming out to power the distributor and also the distributor 5 pin plug is dead, no power.please really need advise...email:gregsariman29@gmail.com
из
Показать ещё 8 комментариев
Добавить комментарий
9 Ответов
Выбранное решение
you may want to check the ignition module in the distributor this was a common problem in the 91 and 92 check the wire harness that leads from the module out of the distributor and feel the wires for internal breaks. Hope this helps
Был ли этот ответ полезен?
Счет 8
9 Комментариев:
I have the same problem it tries to crank but no spark at all. Any ideas if the coil could be not putting the right voltage?
из
It's a 1991 Toyota Camry
из
my 96toyota Camry 4 cylinder ran good got in it started it warming up and shut off all power still on tried starting it no start turns over no fire any clue to what it could b?
из
M working on a Toyota Camry 2azfe,engine cranks but ignitor not providing spark at all. What is the cause?
из
I have a 1990 holden apollo, which is identical to the camry. i have been suggested to replace the starter model part number - IM111. i have the exact diagnostic but due to costs haven't been able to try any repairs. i hope this is useful.
из
Показать ещё 4 комментариев
Your problem could totally unrelated, but I had a chevy silverado truck that would die when running. and just like you i replaced the coil,the distributor cap & rotor and nothing. finally after troubleshooting further it turned out to be the wire harness on the ignition switch. what happens when you crank the ignition....there's a wire that sends the voltage to the coil and in turn to the distributor that delivers the spark. Hope this at least helps you troubleshoot further, Good luck!
Счет 3
So the same thing happened with my 95 Camry ...it actually just stopped all together one day and it would not turn on ,I mean it cranked but no spark....so I replaced the spark plugs ,the distributor cap wires and I got valves seals and gasket ...hoping this will make it work if it doesn't then maybe it's the ignition coil... we'll see...crossing my fingers....
Счет 1
1 Комментарий:
It's been about a month like this ...
из
My 94 Toyota Camry won't start and it drain the battery when I turn the switch key the light on the dashboard turn of so what should I check for anyone help me on that
Счет 0
1 Комментарий:
I have the same trouble for about four months. I tried everything and spent over $1700.00. I kept messing with it not cranking and one day I pulled up to Auto Zone. It seemed like because my post were on the side of the battery instead of the top and I live and work where I travel over a lot of speed bumps. I bought a new battery and a new "hot" (red) connector because when the battery was cable was loose it messed with my security so my car wouldn't crank at all. Well it worked, I have not had anymore trouble with it. I hope Alex that is an easy fix for you. Good Luck!!
из
Turn key on and use an impact on the harmonic balancer bolt so ecm may re-learn . Note. May take up to 50 starts to actually start.
Счет 0
2 Комментариев:
Place a pencil on distributer shaft sharpens end torward reference tab. This pointer is where the computer fires
из
I have a 95 t100 truck got lights but cranks no spark or fuel believe friend changed out efi off a Camry for my truck will this work
из
Has anyone figured out the problem mine will spin over but no spark coil tested fine so I don't know why it's like that please email me at phillipebersole@yahoo.com for any response I'm at a loss
Счет 0
same thing here. Tried new distributor and still. Nothing.
Счет 0
1 Комментарий:
Camry 1992 crank but not starting
из
Ignition coil is bad
Счет 0
1 Комментарий:
My camry was not cranking and not sparking, i change coil module and ignanion, then it sterting now
из
Got it — that’s a classic intermittent “crank no spark” issue on older Toyotas like your 1991 Camry DX 4-cylinder All-Trac (3S-FE engine).
You’ve done a lot already, which narrows it down nicely. Let’s walk through the most likely causes, focusing on things specific to this engine and year.
✅ SUMMARY OF YOUR SYMPTOMS
  • Cranks fine, no spark at plugs.
  • Has power to coil, igniter, and distributor.
  • Coil, igniter, relays, and distributor have all been replaced.
  • Starts after sitting for days → runs briefly → dies again → no spark.
  • All fuses OK.
🔍 1. Suspect: ECU (Engine Control Unit) Failure
Most likely cause.
  • The 1990–1992 Camry ECU (EFI computer) is notorious for leaking electrolytic capacitors that damage internal circuits.
  • When the ECU warms up, it can lose ignition trigger output to the ignitor — resulting in no spark.
  • After sitting (cooling down), it may work again temporarily.
Test / Check:
  • Pull the ECU (located behind passenger kick panel).
  • Open the case and inspect for leaking or bulging capacitors or a fishy smell.
  • If you see corrosion or brown residue → that’s your problem.
  • Replacement or capacitor repair will fix it permanently.
🔍 2. Check NE and G Signals from Distributor
Even though you replaced the distributor, make sure:
  • The pickup coil (NE & G sensors) inside is generating signal pulses.
  • You can backprobe the ECU connector or igniter input while cranking:
    • NE signal (engine speed) and G signal (cam position) should pulse 0–5V AC while cranking.
  • If not, the ECU won’t trigger ignition.
🔍 3. Ground and Power to ECU / Igniter
Verify with a multimeter:
  • ECU pin BATT and +B = 12V (battery voltage).
  • ECU grounds E1, E2, E01 are solid (<0.1 Ω to chassis).
  • Igniter ground and body ground bolts clean and tight.
Poor grounds or corroded connectors can cause intermittent spark loss.
🔍 4. Check for Injector Pulse
If no injector pulse and no spark, that confirms ECU not outputting ignition/injection control → ECU failure 99% certain.
If injectors pulse but no spark, problem may still be in igniter trigger line (IGt / IGf).
🔍 5. Crankshaft Sensor / Distributor Connector
Inspect the 3- or 4-pin distributor connector and harness:
  • Tug test the wires — sometimes the internal wire breaks near the plug.
  • If signal is intermittent, ECU will cut spark and fuel.
⚙️ Summary of What to Do Next
Step Action Expected Result 1 Check for ECU capacitor leakage If leaky → replace or repair ECU 2 Backprobe NE & G signals from distributor Should show AC voltage pulses while cranking 3 Check ECU & igniter power and grounds 12V + good ground continuity 4 Check for injector pulse (noid light) If no pulse → ECU issue 5 Inspect distributor connector wires Repair if cracked/broken
🧠 Bottom Line
Based on your description — starts after sitting, then dies and loses spark again — this is textbook ECU capacitor failure on early ‘90s Camrys with the 3S-FE engine.
👉 Fix: Replace or rebuild the ECU.
Rebuild kits are available, or you can get a remanufactured ECU (same part number) and the problem should be gone permanently.
Счет 0
Добавьте свой ответ
edburak буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 29
За последние 30 дней: 176
За всё время: 71,036
