Launched in October 2014, identified by model number CHDHA-301.
24вопросов Показать все
How to fix a broken case?
I have the original GoPro hero and the attachment clips are part of the housing case which can't be replaced or removed. I was wondering if anyone had any ideas about how to reattach the clips? Is it going to have to be a glue job?
Это хороший вопрос?
Оценка 6
2 Комментариев
I have this problem too
из
The same here. Broke off in the water. :(
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Here is a great solution:
https://www.youtube.com/watch?v=qIk4T9J8...
Был ли этот ответ полезен?
Оценка 2
The switched output board needs to be replaced. It could have just died, or burned out from trying to pull more than it is rated for.
Оценка -1
1 Комментарий:
That isn't related to the question.
из
Добавьте свой ответ
James Roberts будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 27
За всё время: 8,360
