Can this be used to dry loca glue?
I want to fix the glas only on iphone 6, can this be used to dry the Loca glue?
Это хороший вопрос?
Это хороший вопрос?
Uh... Haha yeah. It seems like it will. Don't think you want to use loca glue, though. It has a tendency to "stain" the apple lcds. Technically it's remove able. I would go for oca glue? Or that's what I've heard. Haven't played with it much
Был ли этот ответ полезен?
Thank you for your answer, but i will use loca because that's what all the tutorials say.
Oca is alot better, but also much more expensive since you need at least two machines to apply OCA. If you seal the sides of the LCD first, it wont stian anything, but I'm still finding ways to seal the sides (blue tac etc.)
You will also need a new backlight and a new frame for the iphone 6 if your doing loca. With this uv light i will leave it for 10 minutes to dry the uv glue. This is not that strong if you do it the regular settings it will leak tru the backlight.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,091
