Projector light on and off or off ,only sound /audio no video
Hi
NIRAJ from Navi Mumbai India
I bought Mini projector Rd802
After purchasing within 1 hr adapter burnt sellers sent me new one same day
now the problem is that projector Led is not turning on when projector turned on only audio no video on screen
some times led flashes and turn off
please tell me solution for the problem to fix the projector
Regards
NIRAJ
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
1 Ответ
Выбранное решение
Hi,
The first adapter was it 12V DC / 2A (2000mA) output?
If yes there may have been a fault either in the projector already or in the adapter and that is why the adapter burnt out.
If it was a different output value it may have damaged the projector and that is why the 2nd adapter (if it is the correct value) does not make it work properly.
Check your warranty and contact the seller.
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
I have the similar issue.Brand new unit runs for 15 mins then shuts down but by that time the ac adapter is very hot.Do i need to get a other adaptor
от
I then turn it back on and then it turns off even faster after like 1 to 2 minutes.Its annoying.
от
Добавьте свой ответ
NIRAJ будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 8
За всё время: 548
