Repair guides and support for motherboards and CPUs.
Where to buy replacement CPU socket?
Greetings,
Where can I buy a replacement CPU socket? I have searched and searched and only been able to find one store on eBay in China. Anyone know a place in the US?
www.ebay.com/itm/Original-New-Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262
Thanks
Это хороший вопрос?
Оценка 2
4 Комментариев
"Charles, if you can find one, how would you solder the hundred + connections?"
You do not solder. You heat the socket with heat gun to melt solder balls.
из
Would be better to buy another motherboard.
из
Im bga certified, I just need the part
из
EBay and how much to fix my motherboard same problem jandersen
из
Добавить комментарий
Ответов (2)
Выбранное решение
Charles all searches came up Shipping from China/Hong Kong/Taiwan to worldwide (7 to 19 business days) for the replacement CPU socket Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262. It may be worth trying to place the order on Ebay for the price of part $3.59 and shipping $3.30.
Good luck with the part and installation.
http://www.ebay.com/itm/Original-New-Fox...
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
Оценка 2
4 Комментариев:
They come with solder on the grid. You use heat gun.
из
Or you can BGA Reflow them if you have the balls and stencil
из
You just added a clean socket. No solder on it to reflow.
из
@mayer sounds like robert is referring to a reball. Solder balls and stencil combined with a rework station can accomplish this task.
из
Добавьте свой ответ
Charles Kensington будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 8,467
