ny speedometer is not working but rpm and gas gauge work
Speedometer not working
Это хороший вопрос?
Это хороший вопрос?
Replacing a speed sensor entails 2 bolts and a electrical end this is a common problem with Hondas and Acuras
https://www.youtube.com/watch?v=OZp7xoeF...
This video can help guide you through the process if you are so inclined. the video is for a Honda but they are virtually the same car .
Hope this helps
Был ли этот ответ полезен?
those are all different sensors in your car, the gas gauge is a float in the tank, the tachometer is in your engine and the speedometer is on the transfer case, you are going to need to take it into a shop to get the sensor changed because they would make sure your car is reading an accurate speed after they fix it
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 5,243
1 Комментарий
Probable broken cable
из kent norton phd
