How to take apart the Amp of the Apple Pro Speaker?
Hey, my G4 Cube speaker recently has the cord of amp loosen. I want to open tge amp case to fix it. But I couldn't find any source in the internet. Could you please assist?
Это хороший вопрос?
Это хороший вопрос?
See if this guide will help you: Using Apple Pro Speakers with a class-d amplifier
UPDATE
See if this guide is what you need: Repairing Apple Pro Speakers Loose Cone
Инструкция
Сложность:
Сложно
20 minutes
Инструкция
Сложность:
Модерировать
30 - 45 minutes
Был ли этот ответ полезен?
for anyone else:
I just recently popped my Cube amp open as well. It seems like it's just glued shut, but it's not a chemical glue so you should be able to pop it open with minimal difficulty. I used a piece of sheet metal about the thickness of a razor blade, so a razor blade itself would probably work to open it up.
Just be careful because the bottom half has a groove that the top half actually fits into; you can't just slice a razor straight down because it will hit the bump.
Hey Josh what was your experience getting the inner shell open? I'm at that point and am concerned about damaging the plastic in the process. Any pointers? Thanks!
Just kidding. I managed to get it open easily by working a scalpel into the corner near the cords and then slid a sheet of thin metal like you mentioned slightly farther down and it came apart relatively easily. From the bottom end where the output is, I worked across and the whole thing eventually opened like a book. problem solved!
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 1,765
6 Комментариев
Thank you for your reply. My Apple Pro Speaker is the one come with the G4 cube, which has a translucent shell for the amp. I woul like to know the way to open the shell without damaging it.
Thanks anyway:)
из chogokinaholic
Is there a identification number on it? Like an A1122 number?
из mayer
I don't know. But the picture in this link shows the speaker:
http://blog.pardner.com/2012/08/using-th...
из chogokinaholic
So far I found only this picture
http://www.audioimprov.com/AudioImprov/S...
из roland
Thank you. But the auther didn't tell how it was open.
из chogokinaholic
Показать 1 больше комментариев
