The Trio Stealth-10 MST 10-21, manufactured by Trio Tablets, is meant to be a true workhorse in the Trio Tablet family bringing a larger viewing screen and advanced speeds to the user.
25вопросов Показать все
Why is my device constantly power cycling?
The device will charge fully and drain to 50% than die almost instantly...
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
Most likely this is an issue with the connection of the battery. Try disconnecting the battery internally and then reconnecting it.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
how do I open my tablet
из
@cabrich1957 Assuming we're still talking about a The Trio Stealth-10 tablet, there's a battery replacement guide available here on iFixit.
Trio Stealth-10 Battery Replacement - iFixit Repair Guide
Unfortunately, Ian Russell's solution isn't a great one, as the battery doesn't use a connector that can be unplugged; instead the battery is soldered directly to the motherboard. So you'd need to use a soldering iron to disconnect the battery and reconnect it.
If you're experiencing the same issue as the original poster, I would disagree; this sounds very much like a battery that has reached the end of its useful life and needs to be replaced. That would be the first thing I'd try in order to fix the issue.
Оценка 0
Добавьте свой ответ
Ian Russell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 237
