iPod classic 160 gb dead does not charge
Not able to charge when plugged into electricity, itunes does not identify it when plugged into computer
Это хороший вопрос?
Это хороший вопрос?
Most likely the battery. I just did one of these. Pretty simple to solder the new battery on
Был ли этот ответ полезен?
Here's the relevant battery replacement guide! The hardest part is prying the case open, you'll need prying tools and patience. And you don't need to solder at all =)
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 584
1 Комментарий
My 80gb series 5 classic is dead no display, no disk running noises. It’s mounted permanently on an Apple connector/ stand. The Apple power supply is permanently connected to the (230 vac U.K.) power supply. Are you saying that an expired battery will - prevent charging, prevent connection to iTunes, prevent manual resetting?
из duncanhanning
