This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218вопросов Показать все
Why when I touch the screen it don't respond
My phone had dropped out my pocket and fell on concrete and cracked. At first my phone wasnt turning on then i waited and it turned on but now the screen isn't responding like it say swipe up and its not doing it i actually tried swipe left,right,up and down. What should i do
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
You’re going to have to reset your phone. First, make sure your phone is off. Then, hold the power button and the volume up button at the same time, use the volume down button to go to Wipe data/ factory reset. Then, Let it finish. After this, go to reboot system now and you should be good to go
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Mecca будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 89
