Brake Lights stay on
2002 dodge ram 1500 truck light switch is off but brake lights are still on. I have no fuse book to my truck.
Это хороший вопрос?
Это хороший вопрос?
Check the pedal switch if it is not properly adjusted the brake light will come on as if the pedal was being depressed. You may also want to check the spring return on the brake pedal if its not tight enough the pedal will sag and the light will come on. Hope this helps
Был ли этот ответ полезен?
Check it still no help someone please help me
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 24
За все время: 5,573
