The current line of iPod touch comprises seven (7) different generations.
2600вопросов Показать все
Error Code 2009 when I tried to restore it,what does that mean?
I cant get my ipod touch to turn on no matter what i try. When i do the press home button and power button thing it says i need to restore so i hit restore. But then it says a restore cannot be done with an error code 2009. What does that mean and is there any hope of fixing it?
Это хороший вопрос?
Оценка 11
2 Комментариев
get it replaced from the apple store
из
To fix this problem, you also can read this article.
How to Get Rid of iPhone Error 2009
из
Добавить комментарий
8 Ответов
Выбранное решение
Here, you may have the answer to your problem:
http://support.apple.com/kb/ts1275
Был ли этот ответ полезен?
Оценка 5
I fixed the error 2009 on my iPhone 5 by following this amazing guide http://www.unlockboot.com/2015/09/how-to...
Оценка 2
4 Комментариев:
Thank you, it worked for me.
из
Lol you just replied to yourself.
из
And UnlockBoot is his own website....
из
very cheap website and wrong method
из
Got error 2009 so I tried a different sub cable and port and worked for me
Оценка 2
1 Комментарий:
Similar to this, I plugged the cable into the computer directly (instead of an external port where other cables are plugged in) and restarted the computer. Updated the software and all systems go.
из
https://support.apple.com/en-us/HT204770
Оценка 1
uninstall and reinstall itunes, if not solved then clean ure usb socket, its works or me
Оценка 1
1 Комментарий:
how to clean usb socket?
из
I have the same error during the latest firmware update. During the firmware update, it stuck at “connect to itunen/restore “. The service center told me that the mother board got faulty. What? Firmware update cause mother board damage?
Оценка 1
help me,i try idevices restore error 2009
Оценка 0
1 Комментарий:
Just use a different usb port/cable
из
My iphone 6s stuck on apple logo
And when i connect it to my pc it show “connect to itunen/restore “ but when i try to restore error2009 occure
Plz
Оценка 0
2 Комментариев:
told me mother board faulty at 2 shop's
из
same lmao i was on tiktok with my iphone 7 and it turned off and now when im restoring it it gets stuck in the apple logo ;)
из
Добавьте свой ответ
Stephanie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 92
За последние 30 дней: 389
За всё время: 133,584
