Your device is not compatible with this version
I reset to factory defaults. Apps were working fine until I tried to download them again that is when I recevived the message that my device wasn't compatible for this device.
Это хороший вопрос?
Это хороший вопрос?
Hi,
Have you tried updating the Google Play Store app?
Open the app, tap Settings, scroll down to Build Version, tap to enter. If there is an update option select it and allow it to update. Try to download an app and see if it works.
If it says it is already up to date, try the following: From Main Menu on phone go to Settings > Apps > swipe right to All > scroll down to Google Play Store, tap to enter, tap clear data. Try to download an app. Hopefully this may help you.
Был ли этот ответ полезен?
Is this for a tablet or phone as tablet not mentioned thanks ☺
Hi Dave Clarke,
Google Play Store app should be applicable for any Android based device
I tried, but it's still saying 'This app is incompatible with all of your devices.' . Is there anything I can do?
The I have the same incompatible with you device
i have the same problem. incompatble with my device. but my husband and daughter with same phone and same account have no problem. it all started when i recieved my catcher savings.
Try to download another third party Apps store like Mobogenie
I downloaded APKMirror, and then used it to download Cash App, which was giving me difficulty due to seeing a message saying my device was not compatible. I was successful in downloading it.
Even tho you got it, here’s what I did, I downloaded an older version, and then I just updated it, I couldn’t believe all the screams and yells I wasted on suck an easy fix
Thanks for your suggestion, @jayeff !
But I already tried to update Google play store app but it does not work for me.
While searching the web, I followed MegeByte advice and try to remove Google Account and reconfigure it again, and luckily it works for me.
So far not yet
take off any apps that say incompatible with your phone and download again but do this on a pc and they will work fine.
uninstalling the app > navigate to google play store official website on the pc or Mac with the account currently signed in on the device on https://play.google.com/apps > search for the app you having problem with > click download you will be given option to choose from your linked device with the logged in account and will be remotely downloaded to the phone without asking for permission.
hope that fix if the previous given help didn’t
cheers
Same prob. Tried all things mentioned in this thread other than to redownload from a pc. My Sam Gal Tab 4 doesn't have a USB, VGA, HDMI, etc. port to connect to another device. SD card is all but once you eject the SD card the apps on it are never the same and often times are no longer acknowledged. But, the tablet itself is awesome! Very well made, it's as tuff as nails, it's still super fast, it's big enough to find/not lose, the font is large enough to see, the touch-screen and digitizer were built to perfection, I could go on forever! My main gripe is that it doesn't update itself to be current with the times and apps of today therefore almost everything is not compatible and the option to download is not even there. If anyone has any tricks that work pls let me know.
Hey guys. Just came on here as I am having issues with my Samsung Tab 4 due to it being modified and I purchased it from a seller on Mercari. The tablet is functional but isn't compatible with some app and because of the mods it won't let me update. Just thought I'd recommend a site I've been going to for years for tech help. You may be able to search the forums and find a thread regarding questions you may have on your device and other tech info. http://forum.xda-developers.com
Hope this helps! Good luck!
The issue is not with your device. The issue is the version of Android that is running on your device. You can change the version of Android (to Version 7.01 or higher depending on your device). Version 7 and up are compatible with nearly all Android Apps. To upgrade you need the following.
IDIN to root the device
TWRP to install a new OS
LineageOS
Gapps 7.01 which is Android version 7.01 or higher depending on your device
There are a lot of videos that go through this process.
If your device is running Android 6 or less, it will be useful only as a paperweight short of playing some games and surfing the web. Might as well try the above. I did and it works.
New A11 Samsung yesterday. Haven't been able to use Skyview app in over a year on old device it used to work great on (Samsung Gslaxy Note 3). I'm starting to think the universe hates me. Maybe I'll take comfort seeing I'm not the only one banished.
Hi can you give a bit more information on how to upgrade or maybe a you tube link.....thank you kindly
This error is occurred when your phone rooted or have custom rom on your device
I don't know how to update my Android version without using pc
Your Phone model?
I had this problem too. I couldn´t see a certain app on the play store on my phone, and play store said “not compatible with any of your devices“ on computer. This while my wife with the exact same phone and android version had no issues
I tried:
Remove data and cache for play store app on phone - did not work
Made a factory reset of my phone - did not work
This solution worked for me:
I created another google account (“for my company”), to get a fresh account. Added this account to my phone (you can have several connected to the same device). I closed and reopened play store on my phone (for store to associate the device with the account). In play store on the computer, with the new google account selected, I could see and install the app to my phone.
Problem seem to be a hang up in the google account. Probably some version of “resetting” your google account would work too, like removing associated devices and letting the google account “rediscover” your phone again
Please fix my tablet galaxy tab3 messnger not instol
За последние 24 час(ов): 6
За последние 7 дней: 15
За последние 30 дней: 76
За всё время: 400,519
27 Комментариев
I have same problem
из Balkrishna Vispute
So you mentioned water damage battery and charging issues? That should not be related to this...
из Aiden
Go to your browser preferably chrome. Type in DraftKings apk the first choice pops up . Hit download.you can do this with any app on Android. Make sure you enable third party apps.
из Anthony
Also hear is a link. https://youtu.be/9dOkxF5Egzg it works.. I was able to get it by simply typing DraftKings apk and downloading after trying everything.Goodluck
из Anthony
I had a problem with my Samsung Galaxy S7, some how my Groupon app was deleted and when I try to add it back it's says this version is not compatible with this phone. How ? I HAD it before. I send a message to Groupon and they said it should work, contact my cell phone provider and they said Groupon need to make this app compatible with this phone.
из Marian
Показать 22 больше комментариев
