The Acer Liquid Z5 is also known as Acer Liquid Z5 Duo.
9вопросов Показать все
The screen cracked and the sensor on bottom half doesn't work
I dropped my phone, and when I picked it up, some parts of the glass had fallen out, and the rest is barely staying in place. And the bottom half of the screen doesn't work. Will getting the cracked glass changed help?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
If part of the screen does not light up, chances are the LCD has been damaged as well. You would probably have to do a full display assembly replacement, LCD and digitizer (glass).
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
No, the screen looks like it's fine. The LCD probably needs changing...
из
Добавьте свой ответ
yomamasbutt222 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 1,428
