Sony Cyber-shot DSC-W150 — это компактная 8,1-мегапиксельная камера с 2,7-дюймовым ЖК-дисплеем.
Sony Cybershop DSC w 150 why are my photos extremely over exposed
suddenly all of the photos are very over exposed. I have reset the camera to factory specs but it hasn't helped. Its like its stuck on an iso of 3200.
The auto modes don't help.
Is it likely to be a problem with the sensor?
The images are very pale with visible horizontal white lines very close together
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Did you try selecting High ISO sensitivity?
Also, set the White Balance to “Cloudy”. You can also set this option to “Daylight” as it is suitable for different outdoor conditions.
Был ли этот ответ полезен?
Счет 3
9 Комментариев:
Adjustments to the white balance make no difference
Where do I select High ISO sensitivity? The ISO palette only includes auto, the 80 to 3200 depending on other settings, i.e., no 'High ISO' mode
из
Duh! Yes, there is a high sensitivity setting on the mode wheel, but selecting 'High sensitivity' makes no difference to the result, the images are still extremely over exposed. If anything, it makes toe problem worse.
из
If the issue persists, initialize the Camera to factory settings:
MENU>(Settings)>(Main Settings)>[Initialize]>[OK]
из
I have initialised and reset the camera to factory settings but the problem remains
из
Ok, so I'm guessing it's fine, when you look through the lcds. But, after capturing the image, and viewing it, with the LCD, it's all white and blurry?
из
Показать ещё 4 комментариев
Добавьте свой ответ
Coleen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 30
За все время: 1,997
