Charging jack sloppy, won't charge
Can't charge, jack seems loose or sloppy. Tried several cord, plug, adapter etc.
Это хороший вопрос?
Это хороший вопрос?
The USB charge port on the Kindle may have been loosened over time from use. The charge port is soldered to the logic board and often times the solder joints will loosen and break free. If this is the case then you can usually just solder the loose pins back in place. You may need to replace the USB charge port if the original port has damage such as broken pins and so on. You can use the guides here to get the back case off. Inspect the charge port for loose solder joints or other damage to determine if you need a new port or can resolder the current port. Hope this helps.
Был ли этот ответ полезен?
The charge port needs to be repalaced, refute to ifixit repair guids or take to your local repair shop.
I took it to a small computer repair shop. They told me it was the motherboard. I find that hard to believe. I don’t think they have worked on a kindle before. Where do you suggest I take it? I live in Upland, CA.
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 18
За всё время: 843
