Why won't my Vizio thin and light power on?
My thin and light will not power on. I've tried resetting it. holding the power button down for 56 seconds, and f10, and still nothing. All I have is a black screen that will not come on at all. Can someone please help me?
Это хороший вопрос?
3 Комментариев
Hi,
Does it start with the power adapter connected and on? If not, what lights if any are on when you connect the charger, either when just charging or trying to start? Can you hear (feel?) the fan at the back of the laptop running when you try to start?
из jayeff
No it doesn't start with or without the power adapter. The adapter still turns green or yellow. I don't hear anything when trying to start it. It doesn't do anything. When I try to power it on, the white light on the bottom is on to show when it's off or on.
из Kelly
Hi,
Suggest you contact Vizio (here is a link http://www.vizio.com/warranty?country_co...) Scroll down for PC warranty. Also check if your warranty is still valid. Most manufacturers give a 12 month warranty, valid from date of purchase.
из jayeff
