Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4918вопросов Показать все
iPhone 6 won't turn on
My husbands iPhone 6 won't turn on. It was not dropped and has no liquid damage. We have tried:
-A forced restart (does nothing)
-Restoring by connecting to iTunes & holding down Home button (computer won't recognize device)
-Multiple chargers and outlets
-Replacing the charge port
-Replacing the battery
Do I have any options left?
Thanks!
Kate
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
So if you charge it for a few minutes so it will 'start' and than pull your cable out and put it back in your phone. Does it vibrate or make a sound?
Был ли этот ответ полезен?
Оценка 0
Комментарии:
Hi Simon,
The phone is completely unresponsive. It will not start, show anything on the screen, vibrate, make a sound - nothing.
Thanks,
Kate
из
It sounds to me that your charging circuit is defective or components are missing on the pcb. Open up your phone again and look to see any burnt or damage components. If you do find anything it would need to be sent in or took'n to a repair shop that does that kind of repairs. Hope that helps
Оценка 0
Комментарии:
Thanks for your response. Would a defective charging circuit result in a phone that won't power on even when plugged into a charger or into a laptop?
из
Yes Kate, because if the charging circuit is not working correctly it won't detect the charger so you won't see any charging icons on your screen. Also could be your on/off power switch which also controls your mute and volume functions. I have a charging cable that lights up which helps me figure out if it's a charging circuit issue or not if you could find a local radio shack and sometimes target carry this type of cable. Click on link for a video demonstration of what I'm talking about.
http://youtu.be/47PpmHwzYdU
из
How old is the phone, if it's less than a year old take it to a Apple Store for a replacement.
Оценка 0
Добавьте свой ответ
Kate Baldwin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 633
