Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
19981вопросов Показать все
upper case close badly
Sorry for my english.
My upper case doesn't close properly on the right (above the superdrive)
How can I fix it?
Thank you
Fed
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
The upper section of the case superdrive slot must be deformed by too much pressure applied to the metal when the MBP is moved using only the right hand over the slot. Always use your two hands holding the MBP by the sides when moving the computer. Now to repair the metal deformation use a spunger or a flat non metallic object, insert the flat side in the center of the slot about 1/4 inche deep and gently flip the spunger until the slot original shape is restored.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I'll try.
Thanks a lot.
из
Добавьте свой ответ
Fed будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 571
