Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117вопросов Показать все
HHD restore for iBook 3g
I bought a couple iBook 3g A1005s. The HHDs are clean. I bought OS x 10.2 then tried to install. Message I got was can not install due to no older OS installed.
Do I need the original disks for each unit? Can I just get OS 9.0 and install?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Выбранное решение
http://www.everymac.com/systems/apple/ib...
Your probable system limitations are:
Pre-Installed MacOS: 9.2.2 & X 10.2.1 Maximum MacOS: X 10.4.11
Sounds like you got a system upgrade disk rather than a full installation disk.
UPDATE 1/4/16
There are three different models of your machine, see them here. See which machine you have here and tell us which one you have: :
http://www.everymac.com/ultimate-mac-loo...
Here is a picture of an original gray system installation disk: http://www.welovemacs.com/6913638a.html
Here is a picture of a retail installation disk:
http://www.welovemacs.com/m8621llanos9.h...
Был ли этот ответ полезен?
Оценка 2
30 Комментариев:
thanks, I have the link you provided. The disks I got states install on them,, OS X10.2.. the message I been getting is "Cannot install Mac OS X on this disk. An earlier version of Mac OS X is not installed".
Sooo I have bought Mac OS 9.0, to install first then try the OS X 10.2 again.
I also asked the local Apple store, but they are not willing to help unless I bought from them, that's what it seems like anyways.
Again thanks for you input... I may have just wasted my money on the iBook 3Gs I bought.
Live and learn ;-)
из
If you are trying to install 10.2.0 it is to early, needs the 10.2.1. Is this a retail version or a gray (machine specific) disk? You should have no problem with the system 9 install.
из
won't get the 9.O till next week. Dumb me,,, what is the gray(machine specific) mean? So OS X 10.2.1 install disks should work?
из
Is your 10.2.1 disk a retail disk or is the disk gray?
из
still not sure what gray means,,, the disks I got are retail not copies. there 10.2 not 10.2.1 I think I need the OS type first not the OS X type if I understand the message correctly
Cannot install Mac OS X on this disk. An earlier version of Mac OS X is not installed,,, could be wrong..
из
Показать 25 больше комментариев
don't buy mac's can't up date, have to buy new, reason there getting rich.
Оценка 0
Добавьте свой ответ
John B будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 386
