The microUSB port to charge my pill is broken.
The USB port to charge my pill is loose. Can it be fixed, if so how?
Это хороший вопрос?
Это хороший вопрос?
Here's parts...
https://www.google.com/aclk?sa=L&ai=CLZ0...
This appears to be labor
http://m.youtube.com/watch?v=4LS3ZSpT2Ug
Basically your charging port is worn out, and you need a new one. It can be soldered back on. If you're willing to do the work
Был ли этот ответ полезен?
explain how i do this
You'll need to remove the logic board, then desolder the bad charging port, then solder the new one back on. Didn't realize the video I posted was so terrible
Lauren mail in your beats pill and will solder the part in for you grios.g3mobile@gmail.com
Don't be fooled by the parts, I bought parts similar from eBay & it was not compatible.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 19,999
1 Комментарий
https://www.youtube.com/watch?v=fNGB8KVa...
из nicolasb
