6th generation Android smartphone designed by Google and manufactured by LG. Model LG-H790. Released October 2015.
Nexus 5X USB Parts
With the nexus 5X does anyone know if you can get parts for it anywhere?
I stupidly tried to plug a micro USB cable into the phone instead of the cable it came with.
I managed to strip the pins from inside the port and it now (understandably :) ) won't charge.
Looking at the various tear downs suggest that the USB port is fixed to the mother board so might not be replaceable without the whole motherboard - but I can't find any where that sells anything other than screens for these phones.
Anyone else got any ideas?
Это хороший вопрос?
Оценка 2
1 Комментарий:
Update:
I found a company here in the UK that sells the USB-C port on its own (http://www.mytrendyphone.co.uk/shop/lg-n...) its £6.00 incl VAT, so I order one. When it came I used the teardown guide here on iFix It to strip the phone back to its motherboard and then remove the old broken port with the help of a soldering iron and some solder wick. Then I soldered the new port on the motherboard, it wasn't that hard if you've ever used a soldering iron before, you do need a fairly fine tip though as the pins on the back of the port are pretty small.
The phones been charging properly for the past week :).
из
Добавить комментарий
Ответов (1)
There are still no enough Nexus 5X parts in the market and you have to wait. Or you can send it to the after sell apartement and ask for help.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jason Price будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,990
